My guess is your new control arms are adjusted too long
hey guys, i installed the evo plush 3" springs with rough country adjustable control arms, rear track bar relocation bracket and now the back springs bow towards the rear to the point that my track bar rubs wen the springs moves.
any ideas?View attachment 182892View attachment 182893View attachment 182894View attachment 182895View attachment 182896
I bet you like this jeep a lot more than the last one!
Was the problem the control arm length?
Lol, hell yeah.
Yes the problem was solve by adjusting the upper control arm.
Now i have a ques of the plush springs, why is the truck leaning on the passenger side. Front and rear are lower by a inch, is it a problem of the 3" plush spring or my shocks or something else, also im on a full tank of gas.
Is you fuel tank almost full?
A lot if not all of the JKs have the left lean. Don't worry about it.
I read it wrong, yours is lower on the driverside. So I'll change my question:
Is your fuel tank empty?
no its lower on the passenger side
Left side is almost always higher on just about any lift. They say it's to compensate for driver's weight, etc. Not so sure, but almost every lift I've done leaves the driver's side about 3/4" to 1" higher.
Just leave it the way it is. It is normal to have the left a little bit higher. I would not recommend buying 4 inch springs as that may not give you the exact height your after. If it bugs you that much, you might be able to find some spacers. I would leave it the way it is.
I was just joking about the fuel. I would wait a few weeks and check again. Also try measuring on different parking spot. I had one garage that it did the same thing. My new house everything is level
