jeeeep
So everything Seemed to be tight and torqued.. The frame side front trackbar needed just needed to be a hair tighter before the torque wrench clicked..
When I have someone turn the wheels side to side there is a very minor movement of the track bar on both the frame and axle.. The bolts are not moving at all... I'm assuming since they are rubber there will be a slight movement. (When I say slight I mean I really have to look for it to see it)...
Should it be 100% solid with no movement??
Thanks again!
as mentioned rubber bushing flex is normal but I would pull the bolt and check that the bolt hole hasn't ovaled
