Moochie
Here's one for you all...
View attachment 182806 .
Oil pressure sensor
Oil pressure sensor
What are these called?
Which one goes where?
What's the torque spec on the bolts?
What about this crusty part?
Inside of a T-case?
Inside of a T-case?
E-disco motor?
Top one is a TeraFlex rear lower control arm after one wheeling trip; the bottom one is the front.
Close enough! This is the mechanism that connects the two separate pieces of the sway bar. The actuator pushes on this to disconnect. This was so gunked up that it wouldn't reconnect. I guess you could consider this a part of the motor.
Front axle wheel hub, inside the knuckle? Unit bearing bolt?
Correct again! You really know your Jeeps.
Here's a great resource for torque specs...
http://project-jk.com/jeep-jk-write-ups/jeep-jk-wrangler-torque-settings
Not to hi jack, but this was mine after i scraped out the loose crap. Let it soak in parts cleaner, regreased it, works like a dream.Were you able to clean it out and get it to work again? How much do you charge to help take a look at mine. [emoji6] Wondering if this is my issue?
Those bolts SUCK when a broken u-joint rips the head off one of those bolts.
Who knows what this is?
I'm probably wrong but that looks like an EGR valve.
