TrailHunter
Electricians wire spool?
X2 on that
Was doing some work in the garage tonight and thought this may be a fun one.
It does draw a vacuum, and you can test for leaks but it's not a vacuum pressure tester.Vacuum leak pressure tester?
Yup. I won't fill a cooling system without it anymore.
We had one of those funnels with a plug and it worked ok for topping off, but for a total fill you can't beat the airlift.It is amazing how much easier it is, and how simple the idea is. I use something similar when working on hydraulics. Pull vac on the tank and can pull and change lines without loosing much oil.
Looks a little different, but here it isView attachment 313252
Seems like I’d have seen one in the last 35 years but apparently not
Single Tire Dolly
Contour Gauge.
