Nate Rubicon X Build
Sessoms14X
JKS control arms have arrived. Got the fixed lowers(front and rear) and J-axis upper adjustable (front and rear) to go on. I'll be installing these along with the new rear driveshaft to set the pinion angle.
Sent from my SM-G955U using WAYALIFE mobile app
Sessoms14X
Took some time to give the jeep some t.l.c. today with the weather finally starting to warm up. As you can see the winter road salt did a nasty bit to my Evo C gussets and prosteer ball joints. 20180410_142451.jpg
Rust is definitely not my favorite thing to look at. So I used some Chassis Saver and used a small sponge brush to apply it. Stuff worked great and a little bit goes a long way.
Makes everything look much better. I've never used this stuff before. It says that it stops rust so I'm hoping that it'll hold up through next winter.
Sessoms14X
Just scrolled through your build. Very nice!!!
Appreciate it. I will finally be installing my control arms and rear driveshaft next weekend. LONG OVERDUE
Oh wow that chassis saver stuff did the trick on your rust. I might try picking up some. My axles are beginning to collect a good amount of rust around the knuckles.
Nice build btw!
Real easy to put on. It says to just apply directly on the rust. I did take a kitchen sponge and scrubbed off any paint or rust flakes with the ruff side. This can will last me forever with how easy it spreads.
Well see how it holds up through the winter. Hopefully better than spray paint does.
Patrykjkur
Running for a can of chassis saver now lol. My ruby has 800 miles on it and the rust in the knuckles is already goin. And with just cutting some brackets to install my coils looks like it might do better then the paint I used to seal
