2008 jku wrangler x stock auto tran. Bought new 110k miles
Looking for help and advice on a few issues I'm having.
1st.. Red security light blinks on for a few seconds while driving. I don't have the alarm system, just the sentry key security. Its been doing this for about one month now. I have no clue. Google it, seem there are others with the same problem with no resolution. Any ideals?
2nd.. Transmission cooling lines leaking at the crimped ends (where the rubber meets the metal tube). Seen a video on how to repair by cutting of the crimped ends and replacing hose and using hoes clamps. Would this void or have anything to do with the lifetime powertrain warranty? Also I'm looking into putting in an additional cooler. I've got the hot oil light come on a few times.
3rd.. The dreaded death wobble. It seem to be starting around 56 mph starting from the right side. Did a lot of reading on this. Track bar looks good. What seems to be my issue is the drag link clunky feel (inner) by the wheel joint. Also I notice when checking the ball joints, their is like about 1/16" vertical play in the upper and lower... horizontal looks good. Should they be replaced also? I was thinking rotating the tires to see if their is also a balancing issue with the right front tire.
thanks in advance for any tips/suggestions
