That took abouy an hour..... and omg what a difference.... I highly recommend
Sent from my SGH-T889 using WAYALIFE mobile app
Cut a short piece of wire and crimp one of these on both ends. Once it's crimped then cut off one prong from each side. Stick the prongs into the correct pins.
Where in the jeep do I do this?
Ok guys and gals....
I am looking to UPGRADE my stock speakers and can't make up my mind what to go with... sound/roll bar and dash both take 6 1/2" speakers... DID you know that on Amazon alone there are 2,086 DIFFERENT 6 1/2" speakers.... OMG... How do I choose??
I have always liked Polk, Kicker and Rockford Fosgate....I just want BETTER than stock speakers, not looking for a booming system, just loud enough to hear GOOD when running naked....
I have watched the video on speaker removal and replacement for my JKU, the work I can do with no problem...
Do they need to be a certain depth for mounting? or just whatever?
THANKS
These will work...
http://www.sonicelectronix.com/cat_f31-97_i47_6-5-speakers-2-ohm.html
2ohm tweeters for the tombstones.
http://www.sonicelectronix.com/cat_f31-97_i32_tweeters-2-ohm.html
Or, you can use the first link for soundbar speakers, and this link for the front...you would just not use the crossovers.
http://www.sonicelectronix.com/cat_f31-97_i29_6-5-component-speakers-2-ohm.html
Note, the infiniti 60.9cs tweeters are too large for the OEM tombstones, so they are NOT plug and play, so bypass that set.
