JKAnimal
Any thoughts on the JW Speaker 8700 series led lights for the JK's?
Well from what I have seen in the mags and a few other reviews, they are more expensive and put out less light than the TruckLights. :twocents:
Doknocker,
What carry rack is that on your rig?
Donny
Does anyone on here have their D series routed into their Fog light harness so they don’t have to re route and install another button or will that not work due to the relay missing?
Although those pod lights are bright as fuck, they don't hardly draw any amps so I would imagine you'll be just fine without the relay. Just double check the amp draw on the Rigid lights and add that to the amp draw for your factory fogs. As long as the fuse is bigger than that, you should be fine. I have the Dually D2s on my WJ, and IIRC, I didn't use a relay at all. Along with that, consider how often they likely won't be used (most Jeepers anyways).
Just checked their website, most of their pod lights only draw about 3 amps.
