Check engine light came on so I checked it with a code reader and the code came up P0562, which means low voltage in the system. I have disconnect the battery to reset it which it does for a day or 2 then the code comes back. The jeep is an 08 with a 130k on it. The battery is a yellow top with about 4 years on it. There are no other issues. what are your thought s alternator? Battery? wiring? what is most common? and if it is the alternator is this a difficult job to do by one's self. if it is the alternator I would like to upgrade to heavy duty alternator. so what recommendations do you have? How can I tell for sure if it is the alternator or something else.
Pep boys gave me a 16 dollar quote whelk menace said 60 for an eval of the charging system . Is there a better way with say a multimeter? Any suggestions?
