plastidip front grill and question on prep
cozdude
Guy with a Red 2-Door
Thanks. I had one can laying around,wasn't sure if it was enough. Better get another one before I start.
O|||||||O
JK
yea doesnt hurt. the first time i did my grill i went thru 1 1/4 cans for 5 coats. they were light coats tho. When i peeled it and resprayed it a few weeks ago i used 2 1/2 cans for 5 REALLY heavy coats.
edit - also watch some of their youtube videos on how to properly apply the dip when spraying. youtube "dipyourcar"
NFRs2000NYC
Love plastidip....truly a fantastic product, especially for jeeps. Had it on for 2 years (before trading it in, which was great because the dealer wanted the stock color back) through mud, sand, NJ rockchipping gravel, caked on calcium chloride, NYC salt, and the paint underneath was FLAWLESS. For the front grill, put on A LOT of coats so that it does a great job of protecting paint against rockchips. I generally plastidip things 5 coats or so but the grill I did 12.
This is when I peeled it off after 2 years....notice the flawless paint....
Red Knight15
Just made wife have a mild heartattack , she walked in about halfway thru first coat. Didn't tell her it would come off. 😁
O|||||||O
JK🇺🇸
Toxic
I've had mine on for almost 2yrs and have been to the power wash many times and have yet to recoat. 20130717_175617 (1280x960).jpg Just cleaned it real good with windex actually lol. Did do about 4 coats though.
cozdude
that doesn't look bad at all .... thanks for the pic
no problem. here is another pic from a little father away jst for an idea
BadApple
I tested before i did mine to make sure it would still peel off. I got the white Plasti Dip and had Sherwin Williams mix a can that was bit darker than Gecko Green and put coats on over the Plasti it makes it a little tougher to peel but i like it.
dentdude36
plasti dip works well but honestly its better to have it painted, mine is flat black and to get the bugs off i just use rubbing alcohol leaves clean flat finish
Chattinfarms
Just clean good with alcohol. I've had mine plasti dipped for 6 months and rubbed branches and scrubbed bugs off with no problem. The trick is on applying it right. Couple mist costs followed with several thicker coats
Sent from the business end of my jeep
jeepnjoe
I think I am going to give the plasti dip a whirl. I saw a YouTube video where the guy was cleaning his grill with windex.
It has alcohol, so I don't see why that wouldn't work, although I also use straight simple green.
Craig.Turner
Soap and water for prep. No issues at all. To echo the others, applying in multiple thin coats followed by heavier coats is the key. Be patient.
