Prorock 60 package / EVO High Steer
LO_Rex
I was thinking the same thing. I saw Astroman’s set up last week and the ram is on top
There is not much clearance between the steer arm and knuckle tie rod mount.
Will they be able to move the ram to the top without removing the steer arm from the knuckle?
OverlanderJK
Resident Smartass
Yes. That’s how it’s supposed to be.
When you move everything to high clearance everything becomes tight.
LO_Rex
I wonder if they changed the tie rod hole location on the package PR60s w/ their ram mount. It looks like the tie rod hole is further forward in yours and all the other photos I have seen.
You can see in the below photos my knuckle that there is no way to get the bolts to fit.
Exodus 4x4
Did you get the new high steer arms from Dynatrac when you bought the kit? The arms for the high steer kit are different than the arms that come with your axle.
LO_Rex
Yes. I bought the Dynatrac competition steer arms through you.
In talking to Dynatrac and they confirmed that the holes are drilled in a different location on axles that have their raised track bar bracket and ram mount. It looks like I'm left to either buy a new passenger knuckle or live with the undermount location.
Exodus 4x4
Get the low profile ny-lock nuts from Fastenal and cut the bolts on both bolts. They will allow a lot more clearance.
