The JL's use the same 6-3/4" ram. Jk's too.Just picked up a PSC kit for the Gladiator and it comes with a 6.75 ram. My question is to why this, and not the 8 in. ram offered for other applications?
Dynatrac 60I assume you're still running a factory axle?
I’m guessing I do have the wrong kit, because the cooler doesn’t fit behind the stock grill. Reached out to them several times and they asked for pics. Haven’t heard anything yet, including the answer to my ram question so I thought I would bring it here. Yes on the 72.5.The 8” ram is typically used for axles wider than 69.5”. If you’re running an XD60 WIDE (72.5”) then you ordered the wrong kit. PSC should swap it out for you drama free. However if you ordered their standard width then the 6.75 is what you should be using.
Yes on the 72.5.
I know even with the old style, it was a very very tight fit and to the point I hated the design as it was super close to rubbing the radiator.I did cut the tabs. Taking the honeycomb part of the grill out did gain about 1/2 inch of additional movement. I can slip my fingers behind the cooler bracket, which clearance could be reduced but I still don’t think it’s enough. I’ll get it, I was hoping someone here has come across this already. Disciple, you’re being very helpful.
