Armydog
Since you bought it used it's not a guarantee that you have 4.10's.
Pretty sure there were no major changes by the previous two owners but to be sure I have to pull the diff covers, is this correct?
actually no that calculator i gave you can help you figure out what ratio you have you just need to go at a set speed 45 works in 4th gear which is 1:1 in hi range and get a rpm reading on your engine and then you can calculate mileage off of that :thumb:
Cool. I didn't look at if that well, I'll check it out tomorrow and figure if out
There's always the good ol' "lift one rear tire, spin the wheel exactly one time around (valve stem is a good indicator) and count how many times the pinion yoke turns" method! :yup: Don't forget to put the transfer case in neutral.
There's a catch here, though. If you have an open diff, then you have to multiply the pinion turns by TWO. (Remember how if you lift the axle on a open diff and turn one wheel, the other wheel turns in the OPPOSITE direction??)
If you have a locking diff that you can somehow engage with the transfer case in neutral (like an air locker) or a limited slip (where both wheels turn the SAME direction when you lift the axle and turn ONE wheel), then you don't need the multiplying step...but you do have to lift BOTH wheels off the ground
Make sense??
^^^ thats good stuff right there! :thumb:
Sad sad day today...
Turns out duct tape can't be used to fix EVERYTHING....
Make sense??
Makes sense. I have a locker bypass relay wired in so my stock air lockers can be engaged in any range... I'll try this.
??? The stock lockers are not air lockers they are "E" lockers meaning electric. ??? When disconnected it is the same as an "open" diff.
^ He has an 05 rubi
p
