Loving having dual led switches that turn on the lower led with the headlights- Thanks Paul!
And York belt driven oba
Tank
Needed a bracket for oil filter.
Started with this-
And ended up with this
Thanks David! oba is one of those things where there are many ways of doing it, yet nothing beats belt driven. Electrc compressors can only put out 1.5 cfm, a dual like arb has can do 3.0cfm, but still nothing beats a york at 15 cfm.
The downside is you are expected to air up everyone else![]()
well between his oba and toyota axles im sure he could get the job done :crazyeyes:
Hey hey hey!!! My axles are not foreign!! Dana 60 hp, and ford 10.25. So far from Toyota!!
Who said strong front axle? Yes this front axle did not pass the test
^ that was factory d44's
Thanks Hinrichs!
I got 12 of the 9 watt eagle eye leds-
Went to the local hardware store to get locking nuts for them(or you could use locktite) thread is M10 × 1.0 pitch.
I made brackets to go inside my bumper for oba and an led facing back.
I zip tied two facing down at the frame rails right in front of the sway bar
And then I mounted one led to every body mount (3 each side, 1 rear corners)
Drilled a 7/16" hole, ran 16 gauge speaker wire, zip tied to the top of the frame, brakelines, etc. Soldered, crimped, heat shrinked all the connections and then wire loomed the majority of it. The leds in the bumper have quick disconnects.
My main concern was protecting the leds, and I think they are pretty well protected up in the body mounts.
