Thanks guys for the info, the removal of the belts was very easy (well kinda easy as the fawkers were freaking tight), but let's say straight forward, took about 5 minutes per side. TorX (hmmm 40 0r 45 if not mistaken) on two spots and then a nut to the base.
Am stoked, 3rd row seat, just ordered some Teraflex brackets, and will skip nutserts and go with mounts to body instead. I am deciding in a few days if I just go ahead and modify and add to the cage or go with the RH setup. I like the design setup and the flexibility to remove if needed, but am thinking full cage direction will likely be the plan.
USMC I took measurements on the 2dr seatbelt location and belive they can be replicated using the RH cage mounts. so I will take some pics and post up.
Thanks again,
Gui
