Are you seriously that stupid that you believe everything you read? A quick google search shows $100 bill weighs 1 gram. 700,000 grams is 1,500 pounds. Its not a single ton, let alone a metric ton, or even multiple tons. It would be thirty 50 pound checked bags. Sometimes if you take two seconds to think about something before reposting you might not look like such an idiot.
Well some cat by the name of Elon posted it so that was good enough for me, and I don’t use google but you do you.
I did pull up a calculator just to see what the actual fuck you were raging about and it clearly showed that $700 Million in $100 bills would come out to around 15,432 pounds.
Have a wonderful evening sir.
You think a $100 bill weighs .02 of a pound? 3.5 ounces? Maybe you should start using google.
$700 million in one dollar bills would weigh 15,000.
Are you seriously that stupid that you believe everything you read? A quick google search shows $100 bill weighs 1 gram. 700,000 grams is 1,500 pounds. It’s not a single ton, let alone a metric ton, or even multiple tons. It would be thirty 50 pound checked bags. Sometimes if you take two seconds to think about something before reposting you might not look like such an idiot.
Wait, math isn’t mathing.
$1 bills and $100 bills weigh the same. So if you agree $700 million in $1 bills weighs 15,000, then you agree $700 million in $100 bills also weighs 15,000. The added $99 in “worth” does not in any way increase the weight.
you forgot a zero, $700,000,000 not $70,000,000
$1 bills and $100 bills weight the same. So if you agree $700 million in $1 bills weighs 15,000, then you agree $700 million in $100 bills also weighs 15,000. The added $99 in “worth” does not in any way increase the weight.
You may want to check your figures on that
