M38A1Driver
Great! I'll take a look. Thanks for the education!
Another question if you don't mind. I see in your pic, just like the one I posted, there are three shifters on the floor. I understand the longest would be the transmission and at least one of the shorter ones would be the t-case. Is the third one for the t-case as well or is that for something else?
Your correct on the long shifter. Both of the extra shifters go to the transfer case. The medium shifter engages the front axel (4wheel drive), and the short one shifts the transfer case to Hi, Neutral or Low range. In the picture, if you look real close, you will see another shifter with a black knob between the main transmission and medium length shifter. That one is for the WARN overdrive I installed as an option.
