The best answers to your questions will come from Dynatrac. Give them a call.
So the post by N4x4 is a little confusing as it makes it sound as though all PR44s require custom "longer" axle shafts. Not that I'm in the market right now, but was just trying to understand the post.
Where did northridge say anything about length? They said they can't find a place that will make u joint style shafts for the same price as stock.
If you order a PR to re-use your factory locker your factory shafts or any aftermarket shafts made for a stock housing/e locker will work.
If you order a PR set up for a conventional locker ARB/Detroit you will NOT be able to RE-use your factory shafts or aftermarkets set up for a factory e locker.
I'm pretty sure you can use the outer shafts just gotta get new inners.
Housing widths are the same.
Think that's how it went?:thinking:
Precisely.
Levi
2013 CG JKU 6-speed
Pro rock's that use Factory Rubicon Locker use Factory shafts.
Pro rock's that use Aftermarket Lockers cant use factory shafts because inside the locker the cross shaft on aftermarket lockers is in the center of the locker and the Factory locker has a offset cross shaft . Thus requiring different length shafts.
Hope that helps
David
Ok this helps a bit. Next question, can I upgrade to a 35 spline ARB and chromoly shafts in a "factory" housing ? Currently I have a PR44 housing with my factory e locker and chromoly axles. Also is the 35 spline significantly stronger than 32 spline ?
So when the time comes, should I just get a ARB for a factory setup to go on my PR44 housing or should I upgrade the shafts and locker to the 35 spline ? Dynatrac's FAQ says they don't recommend the 35 spine locker that fits the factory housing
Hope that helps
David
Hey Carl,
Just had ARB 157 with RCV 35 splines installed. There was a problem with the install.
Now, trying to find out why Dynatrac does not recommend the ARB 157 but Ok's the
ARB RD147 ("The RD157 is not approved for use in JK 44 pumpkins by Dynatrac")
