newjkjeeper
There are a bunch and differ in cost and functionality. I have the aev procal that's around $180
Alright thanks man. I'll look into that one
Seriously??? Are you trying to blow their motor? Even if the engine could stay in overdrive (which I doubt with the 3.8L gutless wonder) that would be 2650ish RPM @ 70MPH (which most consider pretty slow). Edit to add: Should a downshift happen on the interstate the engine would be close to the red line due to the large gear change from OD that you mentioned.
4.88
And don't forget a programmer if you have an auto
A little late to the party, but what role does the programmer play in this scenario? Just tells the computer it's working with a different gear ratio to make the proper adjustments?
The '12 and up JK will go into a limp mode if the axle ratio that is programmed in the pcm does not match what is actually installed in the vehicle.A little late to the party, but what role does the programmer play in this scenario? Just tells the computer it's working with a different gear ratio to make the proper adjustments?
I just put 5.13s in on 35, at 70 mph im running at 2200 ish rpms and its a breeze on the 3.8L oh yeah its an automatic!
