Removing the Wrangler decals
Peak
Mine just pealed off, I believe it was around 80 degrees out I used goo gone to remove the left over residue.
wschilawski
Did the hair dryer method and goo gone - did the trick for me. It is quite satisfying peeling those X/Sahara decals off...
Big b
I use one of those if pink rubber eraser and just rub that sticky stuff off. A paint and body guy showed me the trick years ago for taking off factory pin stripes.
daverawr
Peel it off then use vodka / rubbing alcohol to take the residue off. Just put said liquid on rag and wax on wax off. And vodka you can just drink some while doing it 😊
daverawr
Only done it once 😅 use rubbing alcohol all other times.. But technically anything containing high percentage of alcohol would work to get the residue off.
ScoobyCarolanNC
Took mine off a while back. Heat gun (I know you said no hair dryer). Goo gone just made the adhesive sticky & ruined everything I used. Just soaked em in lighter fluid.
