My big worry on Teraflex is they seem to let the marketing guys dictate the engineering.
Has anyone bent a Dynatrac D44 with standard tubes without doing something stupid? Is it worth the weight to add HD tubes? And if weight is really not an issue? Should we all be swapping in full float D60s instead? That's my question.
Interestingly I was at a trade show a few weeks ago and Dana had a display which featured the UD60s and a UD44. The 60s looked ok but I spoke to the rep about the 44 as it looked just like a rubi 44.
Turns out Mopar own the housing design not Dana so the UD44 has a standard rubi 44 housing.
Since Dynatrac doesn't make a complete axle for my WJ, I was recently talking to another company that builds a 44 for the WJ about me purchasing the Dynatrac PR housing and having this other company build it to fit my rig. They weren't interested and tried selling me on an Ultimate44 that fits my rig. The specs weren't much of anything beyond a rubi44 that I could tell. I wasn't impressed either.
You could call Dynatrac and have them build a 44 without the brackets welded on and then you could get the mounts you need. This is how people order the pr60/80 when they do the double throw down since none of the stock mounting points are used outside of the control arms. If they do the high clearance long arms then the stock control arm mounts aren't used either. Look at Eddie and cindy's pr80 video on YouTube
that's my last resort which is definitely an option. The issue (and dynatrac is aware too) is that you can no longer get coil perches for the wj. Don't know why either. They used to be available. So i could cut them off my existing 30 or find another junkyard 30 and do it. The perches have to be inboard by about an inch and moved forward(not centered on the axle, they sit slightly forward). It's not in my immediate future, but i would like to upgrade at some point, so i'm trying to do all the research now. The other issue (which should be easy to remedy) is the steering geometry is different on the jk too.
jk...jk...jk...jk...jk...
Group chant for added peer pressure!
jk...jk...jk...jk...jk...jk...[/QUO
Once you get it let me know... I gotta mint RE 4" lift in my garage collecting dust I'll give you a helluva deal on.
Kidney belt optional.
Only if it comes with a free TF tire carrier.
Damn....I already sold mine...:grayno:
