Rock sliders
jkjurny
Any slider that uses the body mount bracket won't work with the Teraflex Long Arm Kit. The rear bracket angles into the rear body mount well, preventing a lot of sliders from using that rear body well mount point.
Ask me how I know... I'm still looking for a good step slider.
cuongdyna
I think if we cut the 3rd bracket off the two bracket that is left, the front and the middle is strong Enough to work.
I think you need to try it and tell me if it works out for you before I do mine...haha
Rusty
LOD sliders should work with the EVO high clearance Long arm kit, It might just be with the TerraFlex kit. And I measured my LOD sliders with the EVO sliders and the brackets are pretty much at the same spot.
Hope this helps
cuongdyna
I take it you saw Eddie and LoPo's write up on the Evo Long Arm's ? I've got the exact same set up and am going to go over all of the seams with a magnifying glass to look for cracks.
Yes I saw what Eddie wrote up on Teraflex long arm.:crazyeyes: That sucks I just install the arms:doh: I'll keep my eyes on it. The shop that installed it, weld the whole bracket so hopefully that makes it a little stronger. I'll try to post up some pic tomorrow,
Hope this helps
Thanks for info and thanks for checking.
