Rockjock 60 Rear Axle
cboggs
10-13 grand will get you front and rear 60's, $5400 will get you a 60 full float rear. Either fix what you got or go full float and don't waste your money on a semi float. The reason you don't here anything on the semi float G2 RJ60 is because no one wastes their money on it.
Braxtonsag
I’d pass on the sf brother unless you’re bending housings or breaking ring and pinions repeatedly. The shafts arent a ton stronger and you can get the same shafts for your 44.
Carbon has a 35 spline kit that gets you everything you need plus a 10 or 15 year warranty on the shafts. Can’t remember which though off the top of the head
