ScottofKSU
I purchased my Jeep in May of 2020 and wheeled it for the first time in October of 2020. This experience - my first off-roading trip ever - revealed that I have a little natural talent off-roading but that I also have a TON to learn! I decided then to evolve my Jeep in a series of stages so that it is always one level ahead of my abilities so as to hopefully limit the costs to the Jeep of the mistakes I will naturally make while I am learning.
Here is the progress I have made so far on Stage 1 (I will update this as I continue):
Jeep Stage 1 (Daily Driver)
Stage 2 (Dedicated Trail Rig)
Badges Earned
Stock Photo After 33" Tires but Before New Rims
Current Photo
- Upgrade from stock to 33" tires
- Longer Spare Tire Bumps
- Pro-Comp Wheels with 4.00" Backspacing
- Hard Rock Bumpers I got for $40!
- Towing Receiver
- Rock Hard Winch Plate
- Badlands 12k Winch with Synthetic Line (Early add due to my trail buddy being unreliable!)
- Home "Fabricated" Front License Plate Adapter
- Home "Fabricated" Vacuum Pump Relocation Bracket
- Rebuilt Rubicon Axles with Stock Lockers and Terraflex Ball Joints (Front Axle with Artec C Gussets)
- Terraflex 2.5" Lift Springs
- Hockey Puck Bump Stops
- ARB Differential Covers Front and Rear
- Lubelocker Gaskets Front and Rear
- Fox 2.0 Shocks (4 on the Jeep; 4 that came with the axles that I am rebuilding as spares)
- JKS Sway Bar Disconnects
- JKS Track Bar (Rear)
- Core 4X4 Track Bar (Front)
- Raised Track Bar Bracket
- Core 4X4 Tier 4 Adjustable Control Arms with Johnny Joints (Upper and Lowers on Front and Uppers on Rear)
- Terraflex Rear Spring Retainers
- Braided front Brake Lines
- Driveshaft Direct Front and Rear 1310 Driveshafts
- Rubicon Rock Rails
- Synergy Tie Rod
- Terraflex Steering Damper
- Steer Smart Yeti Drag Link
- Uprated Hood Latches
- Tuned CB Radio with Spare Tire Mount for Antenna
- Black Firestick Antenna with Red Tip
- A-Pillar Pod Light Mounts
- LED Pod Lights on A-Pillar
- 8-Gang Switch Panel for Lights and Lockers
- Molle Overhead Panel for CB
- Rough Country Neoprene Seat Covers Front and Rear
- Bulletpoint RAM Dash Mount (Converted to 1" Balls)
- RAM Mount Arms for Phone and Another for iPad for Trail Maps
- Paracord Grab Handles
- Dash Grab Handle Pocket
- K&N Drop In Air Filter
- AEV Procal
- High Clearance Exhaust System
- Genright Boatside Rock Sliders and Rocker Protectors
- Vector Tech Bar
- LED Headlights and Fog Lights
- Amber Tinted Cube Fog Lights
- Crown Brig Brake Kit with Ram Calipers
- Rubicon Hard Rock Double Rear Red Tow Hooks (Installing Soon)
- Full Skid Plate
- Core 4X4 Tier 4 Rear Lower Control Arms
- GMRS Radio
- 37" TA KO2 Tires
- On-Board Air
- High Clearance Fenders - Thinking Metal Cloak Overline so I get the wider fenders for daily driving and can take the outer portion off when I hit the trail...
- Dynatrac PR44
Badges Earned
- Peewee's Crossing (SMORR)
- Guardrail (SMORR)
- Rubicon Ridge (HSORV)
- Snake (HSORV)
- Fun Run (HSORV)
Current Photo
