Rubber connectors
Irish Pirate
Recently I put on new fenders. This required moving the evaporation canister and fuel pressure regulator. I was so worn out that I didn't check the connections when I put it back.
I already had the air intake off so I thought I'd add a throttle body spacer that I've had sitting around for 6 months.
I fired the jeep up and it started screaming at me. All kinds of nasty hissing. I thought it was the spacer. I went to take it off and noticed a few little rubber connectors came off the pressure regulator and evap can.
Got all that back into place and the jeep is purring again.
I've notice that pretty much ALL the little rubber connectors are cracked or dry rotted. Everything needs to be replaced.
Any chance there is a package out there will all rubber connectors. Somebody has to make that. It's not to much to ask is it.
I figure I'll need to buy each one individually. Know anywhere that sells them?
