I'm looking at putting a Skyjacker coil lift on my 2013 JKSU but the local shop I'm talking to recommended a Rubicon Express over the Skyjacker. Is one brand better than the other or is the shop possibly getting a higher sales margin on the RE?
Thanks,
Ty
Thanks,
Ty
Most likely, prolly a dealer for RE and are famiar with their kits which makes install alot quicker for them aswell to charge labor time and they actually get it done quicker.I would choose RE over Skyjacker though, but I'd choose other kits over RE aswell. What kit are you looking at?
depends on where you are going.
You can't just compare brands, you need to compare what each lift kit provides you for the $$$ .
I appreciate the feedback - thank you. I obviously have some more homework. I was told '3.5" Rubicon Express kit with shocks'. After looking on RE's website it doesn't appear that is enough info to determine exactly which kit I was quoted but I'm guessing it was one of the standard coil kits. Price was $804 uninstalled.
As far as application, this is my daily driver but I want to be able to take the family to the OHV trails throughout GA and possibly join a local jeep club, etc. I also plan to change the tires to 34's or 35's.
Thanks,
Ty
I'd like more opinions/recommendations for a quality 2.5" lift kit that would keep the stock geometry (and ride-JKSU with 373 gears) while allowing for full use of 35" tires.. I'd like to stay within about a $1600 budget on the lift. Thanks!
I'm running the RE on my 2 door and have been really happy with it....the kit I bought came with a very nice HD adjustable track bar and no shocks. I found that the rear bump stops were to big and went another route with those but all in all the kit flexed up well and rides nice. I did go with the new Pro Comp Pro Runner shocks which I love, maybe even more than my previous Bilstien 5100's.
All these kits are easy to install, I have riden in a few JK's with the Skyjacker, Rough Country and Superlift kits and IMO the RE rides way better than those.
Make sure that what ever kit you get you get GOOD shocks and check the bump stops out.
What makes you so sure that the bump stops were too big? Typically, they should be about as tall as the amount of lift you install and more than preventing rubbing, they help prevent the over compression of your coils.
As far as good shocks go, they can only do as well as the coils they are paired up with. Coils will make up the bulk of your ride comfort and the shocks will just dampen hits.
If you lift your Jeep, your suspension and steering geometry will change but, with just a 2.5" of lift, it will not change enough to really matter. So long as you trim your fenders or run flat fenders, you should be able to clear 35's without too much fuss. If you like the ride you have now and prefer to keep it, I might recommend that you just install a 2.5" spacer lift and run shock extensions. Doing this will leave your ride just as it is. If you don't have a Rubicon, I would recommend that you at least get better shocks as the Sport/Sahara shocks are a bit too mushy - or, at least for my taste. Being that you have a 3.6L motor, you will want to make sure that you calibrate your speedometer but otherwise, your performance shouldn't be effected too much with the addition of 35's. Going this route can be done for less than $1,000.
Another option is to look into the Rancho Sport kit. If they have a rebate going, you can get it complete with shocks for about $500. It's a bit taller than what you're looking for but, it's a great kit that comes with really strong and well designed relocation brackets to correct your suspension geometry. With that much lift though, you will need to get a new front drive shaft. But, if you can get the kit for about $500 or so, you'll still be ahead as a drive shaft will only set you back about $450.
Eddie, what shock would you recommend to compliment the Rancho sport kit? I've read quite a few posts that say to be sure to upgrade to the RS9000. Also, does the RS kit come in anything lower than the 4" lift? I have the painted flares and am somewhat hesitant about getting them trimmed. Anything I can do such as spacers, ect. where I can avoid modifying the flares but allowing full function of 35's? Also, which drive shaft do you recommend?
Thanks much!
Ty
Thanks for your input! I'm still mulling over if I want to try and install the lift myself.
Trust me, it's easy and I've got a few write-ups that can help you out. For the cost of labor, you can buy all the tools you need with change left over and, you get to use them again and again. :yup:
...the allignment is probably the hardest thing. Also make sure if you do it yourself that you center the steering wheel before driving orr you will break the clock spring (thankfully we have a good Jeep Dealer in our club or I would have had to pay for my broken one![]()
Spring Compressors will be your friend....
