Rubicon OEM 2-Door Rock Rail LENGTH needed for 2018-2022JL
Gobi2DR
Hello,
For anyone that has a 2018-2022 Rubicon JL 2-Door and still has the factory Rock Rails, can you pls give me the Total Length of your rock rail including end Caps
I had a hard time finding OEM Rock Rails for a 2 DOOR but found several options for FOUR door JL’s, so I picked up a new pair of 2022 Rubicon 4 Door Take off Rock Rails.
The specs from front to back look identical, I just need to trim the rear end of the rock Rails to the Correct lengths… it uses the exact same TWO front brackets and I will just cutt off the excess including the 3rd bracket…
If someone could please give me the Exact measurement/length of what a Two Door OEM Rubicon Rail Rail measures w/ end caps. (My plan was to take it to a metal shop and cut off the excess and put the cap back on it and mount them)
thank you for your time.
Gobi2DR
No, unfortunately, it’s too about 30 inch to long, hits the wheel/tire, I even took the wheel off, and can’t get it to sit flush to mark it..
