GraniteCrystal
Most people like running wheels with 3.5" of back spacing but a lot of that is for no other reason than a lot of popular wheels are made that way. The upside to 3.5" of back spacing is that it'll give you a wider stance and therefor lower your center of gravity, it'll help protect your hubs and help prevent rubbing issues at a full turn and stuff.
Technically speaking, your center of gravity is the same. You do have a wider stance so you're less likely to tip over, but nothing has moved in the vertical direction up or down and left to right is symmetrical (left wheel moves out as much as right wheel) so center of gravity remains unchanged.
Here nor there though. The point you're trying to make is correct.
