Moochie
The completely stock was when asked if I had a cold air intake
You need to update your profile. And yes, it is necessary to adjust your pinion angle when you install an aftermarket rear drive shaft.
My profile! for clarification I bought the JK with the lift on it, I did not know it did not have adjustable control arms.
I plan on buying upper control to move the pinon up to correct the caster, My question all along was what could make that noise that I have on video. after looking at the lift I saw that it did not have adjustable control arms. which With all my reading and education I know if you lift a two door more than 3" you need after market drive shafts.
So i'm going to buy control arms and see what happens. if anyone can think of anything it might could be that would be great!
Ok took off the rear drive shaft and no crazy loud sound. Could it be bearings? Or maybe the ring and pinion?
http://youtu.be/Do4a4D-th14
Is the noise only under load? I had a pinion bearing go bad and it would only make the noise above 25-30 mph and only when on the gas. It was so load sensitive that if I was using cruise control, you could make the sound quit for a second or two by tapping the (-) coast button for the cruise, taking the load off the rear pinion/drive train. Here's a link to a video I posted up. I would think if you've removed the rear shaft and the noise stopped, it's either u-joint or rear end bearing.
http://wayalife.com/showthread.php?t=14050
THAT'S IT!!!!!! same sound I have whining like crazy when your on the pedal let off and no noise!! now how hard is it to change??
Hijack here for a min if i may????
I have had some "clicking" from the front and finally got into my shop ..
Turns out there is play in the front shaft and leaking from the diff at the pinion.
He said the bearings are shot. Along with my axle joints.. So he quoted $500 for the job. This a decent deal?
Seems the breather tube came off the front diff while wheeling and sure mud and water got into and totally screwed everything.. Lesson learned now! :banghead:
And if this is the issue, and I'm paying for a new bearing, thinking I can pull the trigger and do both gears upgrades for the $ 1500 range with Yukon gears. I mean sense he'll be in there anyways.
I do plan on 35s next tire purschase from my 33s, so whats best. 4.56 or 4.88?
Mind you I only have a D30 up front.
The whining sound
