bobfriesenhahn
Brakes have limited thermal shedding capabilities (and wear out) whereas the engine is much larger and has a large cooling system (with radiator and exhaust pipe) to shed heat. When brakes are overheated they stop working very well, and may suffer damage.When off-road, I select a gear that lets me descend without relying on the brakes, whether the rig has an automatic or a manual. Brakes are used sparingly to prevent over-speeding, ease the rig over drop offs and prevent overheating the brakes on long descents.
Under most circumstances, compression braking gives the driver greater control and is smoother than using the brakes alone.
If your technique is to descend using the brakes rather than engine compression and gearing, that’s fine. However, it doesn’t make this thread retarded.
It would be nice if the Jeep engine and transmission had special mechanical capabilities to help manage descent, but engines and transmissions are sourced from a worldwide market so they are unlikely to have more than software tweaks to help manage descent.
Anything to save the brake pads and rotors is a good thing. Not retarded!
