MSJKU11
ah ok, the stock DS is a single piece. With the 2.5" lift it may be enough to wear the bearings out on the stock repezza joint.
while there are rebuild kits available, IMO the stock DS is not worth repairing or spending money on a rebalance.
You'll be better off getting an after-market double cardan drive shaft. It'll be able to handle the articulation angles better as well.
Before you do anything DS related, have you checked the caster angle? you should be at stock angle or real close to it with the 2.5" lift.
https://wayalife.com/showthread.php...nt-End-Alignment?p=42391&viewfull=1#post42391
when you had the DS off did you happen to move the ends around to feel for any binding or grinding - indicators of worn bearings in the repezza joint
I actually already replaced the cv joint a few months ago on the front DS. I really want to upgrade to aftermarket shafts but my budget won't allow it right now. If I can balance it for now, hoping to upgrade next year. I haven't checked the caster angle but will do it as soon as I can, thanks for the link and info. BTW what do you recommend for shafts? I keep hearing good things about Adam's or Tom's.
