JeepFan
I found a bigger dirt mound and sure enough it worked. I then disconnected the front end all together with the manual disconnects and it stuffed the tire 2-3 inches more into the wheel well. I then tried it again with the disconnects connected and the sway bar disconnected and sure enough it wasn't as much. I think its some how binding on the passenger side. I also did notice the springs seem to be really stiff or is that common?
Hmmm...Looking at this pick, something doesn't look quite right. It almost looks like the link is binding up on the spring. :thinking: Do you have other pics of the links and sway bar you can post up?
As Eddie mentioned, with one of the sway bar links detached from the sway bar and the disconnect light on solid, you should be able to move the bar up and down.
