Exodus 4x4
So there has been a small change of plans. Due to Synergy’s back up, I will not be able to get my HD tie rod in a timely manor. I’m being told a minimum of 75 days. So I’m making a change in the build!
Instead of my synergy tie rod, I’m going to order:
- Synergy Steering Stabilizer Relocation Bracket
- Fox 2.0 upgraded steering stabilizer
I know this upgrade isn’t needed, but after feeling the weight of the tires yesterday for the first time, it will help my piece of mind.
Once the Synergy backorder clears up, I’ll then(probably later this year) order the HD Chromoly Tie Rod, HD Drag Link, and Sector Shaft/Track Bar brace, and just redo the steering all at once. These are not absolute must haves, so waiting a bit on them won’t be harmful. ThoughtS?!
Did you need a Synergy tie rod? I have all the Synergy steering components in stock including the track bar brace and sector shaft brace kit.
