BaddestCross
Thanks. Neither can I.Nice refresh you got goin on there! Can’t wait to see the tires on. [emoji1360]
The front axle? I had gussets installed when I got my 35s. I've got Rare Parts ball joints, Chromoly axle shafts, and Currie steering links... Other than that, I'll run the factory 44 until it's dead.Did you already reinforce up front?
NO MORE SQUEAKING from the rear end!
Now you can turn your radio down! Looking good! :thumb:
Since I'm adding to this thread, I should also update with the little stuff...
I relocated my CB antenna because the tailgate bracket was breaking. Ignore the tennis ball - it's only temporary for testing.
A Rugged Ridge X-Clamp with a right-angle mount.What mount did you use for the antenna?
I really appreciate you passing them on to me.Those look great!
I really appreciate you passing them on to me. [emoji482]
Once I threw away the instructions they have been installing fine.
Actually, no. The parts in the bag have been working fine. I was short washers, but the ones off the old fenders were the same size, so I'm good so far.Happy you’re putting them to good use. I assume you got new fasteners. It seemed to me that the fenders were decent but the fasteners were pretty crappy.
Lol. Oh, there will be pics.Upload pics. Glad you making the jump to 37s. View attachment 303654
Sent from my Pixel 2 XL using Tapatalk
You and me both, brother!I cant wait to see those things on! I'm like 2 weeks away from ordering 37s and I really wanna see how it goes for you with pretty much the exact same set up
You have the rear OMEs right? I have the 2" plush rides sitting in my garage I'm about to order the OMEs and the 37s then I have 3/4" spacers front and rear if I need them. I measured like 15 times for those front shocks and even with just 4dr fronts and the 3/4" space (2" ish of lift) the 4" lift shock works perfect up front so I think you will be set. Even at 2" of lift they don't unseat the coil at full droop.You and me both, brother!
I stole your front shock size, so I hope we're as similar as I think.
Do you have rockstars in the rear too?
