NOTE TO SELF: 114k - Transfer case and diff fluid change... Found one metal chip in rear diff
I changed the transfer case fluid and gear oil in the diffs. T-case oil was a little dark, but not horrible... No burnt smell. This is the first time I changed it, not sure when it was done last. Way overdue, but it looks like it was "okay."
Rear diff oil was pretty dark, a bit of fine metal shavings and one small chunk on the magnet. Really should pull the cover and check the gears.
Front diff oil wasn't bad at all. Still could see a hint of the original yellow color in the light. Had the gears changed last year about this time, so estimating about 24k on them. Need to do another oil change at 129k... Want to do a 15k interval.
Found exhaust brackets loose... Only thing holding the exhaust together were the rubber hangars. Tightened up.
Build Thread - Adventures of Fiona -
https://wayalife.com/showthread.php?t=47407
