The assumption was made that the whole Fucking East Coasters Crew was gonna go....![]()
You know what happens when you Ass U Me![]()
You know what they say when you assume....... ass [emoji23]
Keep us updated. Let me know when you get here too lol. Maybe I can see the beast and ride with you.
Sent from my Pixel 2 XL using Tapatalk
Yes. About an hour or so away.LOL, now that's a funny idea! :hmm:
Will do! Do you live near Cary/Holly Springs?
Soooo, finally got sick and tired of the chirp-chirp-chirp-chirp-chirp which means that, yes, I bent a rear flange once more.I was able to put up with it when I had the hard top on it as I couldn't hear it. Now that I took it off and haven't had the doors on in over a month it finally pissed me off enough that I swapped my new spare in the other day. Sounded like there was a kid in the back seat with one of those fucking Audobon bird whistles going non-stop. :crazyeyes: I think I'll use the bent one as the spare as it's just slightly bent and definitely not visible. Splines looked pretty good tho.
Sucks but at-least you get your sanity back. It’s worth having a spare anyway. I might order a set just in case.
Nice work. I think the bent one should be fine for a spare.
Find a friend with a press and straighten it?
And you did it when exactly [emoji848][emoji848] was there a run recently [emoji41][emoji41][emoji41]
Gah... I always assumed the noise was the brakes since it goes away when I tap the pedal. Now I'm hearing it's probably the flange. If that's the case then my new shafts should cure that annoyance as well.
Just remember when you go 60/80 that Brute set the going rate for your used PR44/60...
Sorry about your luck btw.
Mine is starting to do the same thing, chirp chirp chirp..... it’s annoying as hell.
Sorry to be the bearer of bad news. Good thing is you already have the fix for it :thumb:
Can you really do that? I thought once they were bent they were toast.
