The inevitable 2012 JKR Sway Bar E Disco won't disengage anymore.
Try disconnecting the wiring harness from the disconnect motor, clean it out and the re-attach it making sure that it is securely in place. Sometimes, they can work themselves loose and that will effect it. Also, water can get inside and that'll effect it too. Of course, if you are still under warranty, I would see if you could get it covered.
I've definitely been a little busy, but I finally got around to checking this out last Sunday. When I took the connector off, it was clean and dry. Hopefully it stays that way for years to come. Thanks for the great advice. :rock:
