The Morph of Murp Murph a Mojave Sand JKUR
Got front axle on. Still need to adjust and torque everything. Probably a job for the morning. I'm going to sit here and stare at it for awhile[emoji4]
Curious how long it takes you to do both axles. All just turning wrenches? Any special tools needed?
Build thread: http://wayalife.com/showthread.php?t=32769
I spent 5 hours taking front axle out and getting the PR installed. Had to run out to buy 2 bolts and rent a ball joint separator. The joint at pitman arm didn't want to come apart.
I still have to measure everything to make sure it is centered and angle is correct. I will then torque everything down. Hook up brakes and bleed them. I would guess another hour.
