could you do a parts right up for the parts need to build this
I like what I see and being able to do 2 at once would be nice
I am very happy with this setup. I can simultaneously deflate two stock 32" tires from 35 psi to 20 psi in 1 minute - 10 seconds. I can then inflate them ( two tires) back up to 35 psi in 3 minutes using my Superflow MV50 portable air compressor.
Parts:
1. ¼” Air hose with ¼” male ends. I cut about 6’- 2” off each end of a longer hose coil ( I purcahsed this polyurethane air hose from harbor Frieght)
2. Roll of pipe thread Teflon tape ( use Teflon tape on all threaded connections).
3. ¼" NPT Coupler-Cross (4-way brass cross connector).
4. ¼” barb fitting with ¼” NPT male ends with hose clamps ( 2 each to connect cut end of air hose to coupler-cross)
5. Quick connect locking closed air chucks for connecting to tire. (I purchased mine from enco.com)
6. Tire gauge.
7. 1/8” x ¼” NPT brass connector. (Remove valve stem chuck from tire gauge and use 1/8” x ¼” NPT brass connector to connect gauge to top of coupler-cross).
8. ¼” Full Port Valve.
9. Air Compressor quick connect fitting (connect to end of port valve to provide air compressor fitting for airing up tires). I modified my portable Air Compressor hose with a quick disconnect fitting to connect to fitting on port valve (less restrictive than the a valve stem chuck connection.
Attached are some close up photo's:
