Floor jack, bottle jack, jack stands, torque wrench, socket/box wrench/torx set.
Outside my misc hand tools, best money I spent on tools was an air compressor and air tools.
Didn't "need" it but has been one of the most handy purchases I've made. When wrenching on anything it saves a lot of time and effort. In addition to wrenching, I've used the air compressor to fill basket balls, bike tires, inner tubes (for snow and rivers). I've used it to power a sprayer to texture and paint the walls in my house, then with a nail gun to install the new trim in each of the rooms. Soon it will be used for re-roofing the house.
In addition to that, tools I waited too long to buy, and once I had them wondered why I went so long without.
Large Bench Vice - To hold just about anything in place. I've used mine as a press to change u-joints, hold an axe head for sharpening, as a metal brake, and anvil.
Grinder - shaping, sharpening, shortening, rounding off misc metal.
Sawzall with metal, wood, and wrecking blades. Makes exhaust system removal that much more fun. Removes walls in a hurry too.
A large tool box - Tools collect. Keeping them organized is a must. Find the largest you can afford. It will follow you the rest of your life if you get a good one.
A bench to work on - I know this isn't considered a tool by most, but it beats the hell out of being on your knees on the garage floor trying to do anything. Mine is 24" deep, runs the length of the garage on one side, and width of garage at end. I put it at a height I can work at without hunching over. I can lay out a complete suspension on it, I've rebuilt a d44 and 9" on it with room to spare.
Anybody have a recommendation for a good but not crazy expensive air compressor? Thanks for all the responses, btw.
Didn't "need" it but has been one of the most handy purchases I've made...
The challenge with air tools is that they require a LOT of air volume (hence bigger tank). The compressor itself can't create enough compressed air at the pressure needed to run the tools without an air reservoir (the tank). The little $150 3-gal pancake type compressor units create enough pressure but not enough volume, they are meant for tools like nailers that don't require as much volume, or filling up tires, etc. might be able to drive a 1/2" impact gun to take off lug nuts but would likely have to wait between each for tank to refill...the models with standard 25-30 gal tanks work great for most air tools (like 1/2" impact gun and air ratchet), would have trouble keeping up with high volume tools like a die grinder where you are doing constant tool use for extended period of time.
I will tell you that that my brother had a good quality pancake type compressor he used for other stuff and instead of buying a new unit for auto use he simply added a separate 25gal tank inline which worked well.
I refuse to work on your Rig while you hang around to watch. If you stop by to watch all work on your rig will stop immediately.
I went and priced air compressors today and the guy at Lowes said I need a 30 gallon compressor to run air tools. That one was about $500 but they had ones around $150 that had 6-10 gallon tanks and looked like they would work just fine. Anybody had problems running an impact and other tools off of the smaller compressors?
