V Linker MC +, wiring location
Trail Bud
I have a the V linker MC plus, programmer.
Are the cable locations under the steering column? The cable to hook up the programmer. (See pic)
cables that needs connection
kevman65
Safety Gateway cables, left of steering column, back a little ways from knee bolster and UP.
Pain in the ass to get to, lay on your back and look up. You'll see the back side of the connectors, push in tab and wiggle each one out.
Good luck.
It requires suitable working conditions (not 117 degrees) and hands to get the security gateway cables off. I failed. It seems that if I had pushed the driver's seat all of the way back and removed a car from the garage, I might have succeeded.
I could finally find the connectors after removing the plastic panel below the steering column and looking up at the right angle.
Trail Bud
I found the write up Eddie did on tire size correction. It shows how to access the plugs without too much trouble. Should have started with this.
