Wave
crlang
Looking into 315/70/17 and 35/12.50.17.
Anyone running the Goodyear Territory MTs?
Found a good deal on a set needing feedback
Never ran them, but I’ve heard they’re on the softer side and the tread is deep but so close together that they don’t perform as well as other M/Ts that have been around a while. I personally would look at Nitto or Toyo.
As far as the size those are essentially exactly the same and will just vary in load rating depending on the tire brand and model you go with. Something like a C rated tire will ride softer and have a softer sidewall, whereas an E will be more durable but a bit harsher. Most 35” M/Ts will be E rated and what I’d prefer especially if you do some real off-roading - they can simply be aired down lower to something like the 27 psi I run in my 2 door to help with the ride on road.
