What brand.
Prime8
Trail_Creeper said:
What did you use to get the metal shavings out of the tubes? Magnet?
That seems to be my only worry about putting the sleeves in at the house.
I think its in the EVO install directions... It just tells you to push a rag down your axle tubes before drilling, with a string tied to it that is long enough to hang out of the end of the tube. Then drill your holes and pull the string. The string will pull the rag through the tube and pull all the shavings out.
Trail_Creeper
That was what i planned on doing. I'll have to see if i can download a copy of EVOs installation in a .pdf to double check.
