What did Brown Santa show up with today..
JKbrick
I have this with the Arb twin. The easiest way is to take the whole seat out buy removing bolts to the floor. Take it out flip upside down and take out all the bolts securing seat to track. All the bolts have to be loose to squeeze that in, it's a thought fit. Mount the compressor on and put back the whole seat. It is fun lol, extra set of hands might help maneuvering the seat back in. Don't forget to do blue loctite.
I ended up taking out the battery tray to route the compressor power wire through the grommet that is right under the glove box. I didn't want to splice and extend the wire and risk losing AMP's.
MY BUILT/REBUILD: http://wayalife.com/showthread.php?44123-Rebuilt-of-a-Billet-Silver-mall-crawler&p=859931#post859931
Great! Thank you for the advice since you have done this, I appreciate it. Is your air outlet under the seat as well?
VeruGE*144
VeruGE*144
Download the metal master instruction. You have to disconnect the plug to for the airbag sensor under the seat. Make sure you don't cycle the ignition while it's disconnected or you will have to go to dealer and have them relearn that sensor.
I replied to you other question by forgot to quote......
Apdski
Took advantage of a sale and pulled the trigger on some bionic eyes. Little corny, but literally night and day difference. JW speaker cyborg eyes. IMG_5686.JPG
JKbrick
Yes the compressor comes with the adapter to receive the hose end . I just used one bolt to secured it right to the track of the seat for now. I plan to add and air tank some time and I will most likely re route everything when time comes. I'll try to get a pic later when I am by my jeep.
I have some aluminum cylinders from work we used to use for lp gas that are about 6" dia and 30" long. I thought about getting one hydro tested to make sure it is safe and polish it up for an air tank
R
RockyMtnAnvil
Guest
What did u get instead of the coopers?
Sorry, just saw this. I started to mount the STT Pros and found that they have a fairly thick bead. Started coning the bead lock rings. I swapped them out for Trail Grapplers. Two weeks later I see Eddie running the Pros on his Slabs... turns out I just needed to give the bead a bit more time to conform. Next time I guess.
VeruGE*144
Bunch of random goodies, stuff to put my hydro assist together and some new pods since some asshat stole my old ones
Build Thread - "Jenny"
http://wayalife.com/showthread.php?41740-The-build-of-Jenny&highlight=build jenny View attachment 250925 View attachment 250926
Which psc kit did you go with?
RockinAZJK
I actually didn't. While I would love to have a full psc kit I just can't see spending the money at this point in time. I have a buddy who actually has drilled several boxes that is going to port and tap mine. Then it was down to hoses, a ram, cooler, and a few other odds and ends. Went with psc hardware and ram, and had hoses made by the Redneck ram company
