I just ordered the ARB 50 quart, thanks gang for all the help. Still looking at all the ways to mount it securely in my Rig.
I bought the ARB tie downs. The metal handle hooks are sweet, but they don't work if you're using the little JK floor loops. I found it easier to use a pair of short 1" cargo straps loops through the handle. Now if you do a slide or mount on a drawer, then the ARB tie downs would be nice.
A couple of us run cable bike locks through the handles then the seat frame if that is what you're referring to. Mounting...You can use nearly use any straps or webbing. There is also a hard mount via the rubber feet.I just ordered the ARB 50 quart, thanks gang for all the help. Still looking at all the ways to mount it securely in my Rig.
I use two turnbuckles and two, one foot sections of coated chain. Works great and its a quick install and removal. Turnbuckle mounts to the floor loop, chain around the handles, to the turnbuckle, then hand tighten.I just ordered the ARB 50 quart, thanks gang for all the help. Still looking at all the ways to mount it securely in my Rig.
I got my 50qt fridge and wired it up. Headed out today 4wheelin to test it out in the heat and trail.
How did it turn out in the heat? I'm from phoenix, nuff said, so I'm interested.I got my 50qt fridge and wired it up. Headed out today 4wheelin to test it out in the heat and trail.
The fridge did Great! I'm glad I got it. It does better with stuff in it.How did it turn out in the heat? I'm from phoenix, nuff said, so I'm interested.
Sent from my SM-J320V using WAYALIFE mobile app
