OverlanderJK
Resident Smartass
So your going to cut your body where it's rubbing...groin?
That’s chaffing isn’t it?
Perhaps an ice bath could lessen the effect of a sawzall...
Never mind, I looked closer at the picture, it looked like the seem expanded and broke up but i can clearly see now that's where it was trimmed . Lol [emoji2357]What caused the body to do what? Rub? It’s just low. I could have lifted it some. And the new tires are taller than the old ones.
So today I decided to replace the leaky upper engine oil pan gasket on my 3.8l. So tore it down and noticed that I hit a rock lately which slightly dented the steel part of the pan near the drain. So I figured since it’s out, I’ll gently massage the dent. So, after “massaging” the pan, reinstalled everything, added engine oil, then before I fired it up, I glanced underneath and see a six inch puddle of fresh oil. Crap! Upon closer inspection, the oil pan cracked where I massaged it. S@$T. So drained the oil, removed the sheetmetal pan to weld up tomorrow. View attachment 333009
I drilled out the ends of the crack to prevent future spreading (see red circle). I’m now concerned with this other “ridge” (see green circle), so I’ll build it up on the inside to hopefully prevent a future crack. View attachment 333010
Looks like I need to install a oil pan skid in the near future.
And the PCV change didn’t hold. Looks like a new motor is coming soon. Only 500 miles since the change.
Are you still holding out for an LS?
Today I put the finishing touches on my dual battery system. View attachment 333490
Sucks that your having so much trouble with your new to you Jeep. Its a bad ass ride tho so i bet its worth the trouble.View attachment 333505
Transmission decided it didn’t want to shift anymore so I was finally able to lock it in forth for the rest of the drive home.
That’s a super clean install
Thanks, it has been quite the project that started with me peeling the bed liner of a storage tub kit cause it just didn’t look right to me and then evolved into this.View attachment 333521View attachment 333522View attachment 333524View attachment 333525View attachment 333527
