Well I got a few more things done...real pain to do but I made it work. Mounted the rear bumper and got the sensors to work...fucking pain nothing went right... license plate holder and lights done.
So the bumper didn't come with any way of holding the sensors in the bumper so I pealed the factory holders off the factory bumper and mounted them to the Genright bumper.
But as you can see they got smashed by the cross member...so I drilled holes in the frame to make room. The outside ones cleared so no need to do anything to them.
The Artec plate holder I ordered had a few issues too. first I never thought about me running a spacer/adapter on the EVO tire carrier which flips the bolt pattern upside down...so the bracket will not fit the wider bolt pattern that now is on top. I made a bracket to fit the wider mount and welded it to their mounting part.
The one I made...it clears the camera lens, can not see it in the camera at all.
I used the factory wires to the rear license plate to use on the new plate mount....I ran them from the bumper harness through the tub at the jack storage area, there is a drain plug and I just ran the wire through it....then along the weather stripping through the wire protector into the tail gate then out to the tire.
The plate holder is supplied with screws that thread in the plate holder that has welded nuts on the backside to hold the plate...standard thread. The LEDs are metric ? so I had to drill out the threads to install the LEDs.
Done
