If you check my build thread there is a place right behind the batter that goes directly into the cabin area. It takes some body twisting to get so the where it comes through but works. Additionally there are two foam plugs that you can use.
No. I used a long drill bit on a slow rpm on my hand drill and went slowly. Then fed the loom with the wires through. I have eight 14ga wires inside that.
