TeamFaust
I did some searching and didn't see any specific threads on this/these topics (or maybe I was unsuccessful in locating) so here goes.
Situation: The OBD-II in my 2008 JKU has been kicked enough times (I know I'm not the only one to accidentally kick that sucker) that the plastic retainer thingy has broken and is long gone the the port connector just hangs there. Not really a big deal because I have it connected to a Trail Dash unit so it is effectively secure.
Problem: In AZ where I now live in order to have the required emissions test done the port must be secured to the bracket so that the emissions "tech" can just push it on. They will not hold the loose port and plug in their connecting cable
so two questions for the group:
1) Does anyone know the part number for the plastic OEM retainer gizmo so that I can "properly" re-secure the OBD-II port to the existing bracket. Otherwise if anyone else had had this issue any suggestion to secure....otherwise might have to try to finagel a zip tie option in the sort-term.
2) Has anyone used one of the OBD-II Y-splitters to create a second OBD-II port? Do they work / any complications? I'm thinking about installing one so that I have 1 lead "permanently" connected to the Trail Dash (or other future aux computer unit), and then 1 lead in the factory bracket always available for any repair tech/emissions/??? access so as not to disconnect my Trail Dash every time there is a need for external connection to the OBD-II
Would appreciate any input from those that have experience with these.
