It should be noted that measuring how much lift you have is not the same thing as how tall your Jeep sits. You can install a set of Portal axles and run factory coils to give you ZERO inches of lift but, still sit 4" taller than stock. A ProRock 60 is also a much bigger axle than stock and how tall your Jeep sits won't necessarily equal how much lift you have.
